Hi lee,
I could not get to a definite solution, I then decided to upgrade to DotNetNuke 4.3.3 ( Final Version ) . The sad part is that I ran into more errors.
Object reference not set to an instance of an object.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
Stack Trace:
[NullReferenceException: Object reference not set to an instance of an object.]
DotNetNuke.Entities.Portals.PortalSettings.GetPortalSettings(Int32 TabId, PortalAliasInfo objPortalAliasInfo) +316
DotNetNuke.Entities.Portals.PortalSettings..ctor(Int32 tabId, PortalAliasInfo objPortalAliasInfo) +98
DotNetNuke.HttpModules.UrlRewriteModule.OnBeginRequest(Object s, EventArgs e) +6417
System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +167
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +117
Base on my research I have reached my final solution to reinstall DotNetNuke 4.3.3. I am just getting tired of reinstalling and getting errors left and right. However, I am not going to give up!!
If you have any information about this can you please help me.
Thank you
