You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
Skinning Toolkit
Skinning Toolkit
Fixed Container Skin
Last Post 07/02/2008 3:29 AM by
. 3 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Minh
06/20/2008 9:45 PM
Hello Forum,
I'm new to DNN and been playing around with the DNN-Blue skin. I've noticed that the container will expand to fit the length of any modules even though I am using the fixed width skin. Where do I force the container to be a fix width and height? eg. I want my container width to be 200px and if any module title that is longer than 200px it will either wrap around or the font will decrease to fit into the 200px restriction. Thanks for your help.
-Minh
06/25/2008 5:03 AM
If you look in the skin.css file for the DNN Blue skin you will see the widths for each content pane are specified in the:
.leftpane
.contentpane
.rightpane
classes.
So, there you can change the width for each of the content panes. However, if you add a text module into a content pane with a width of 200px and you place in the text / html module an image of 250px it will still force the width wider to 250px, so you need to be careful what type of content you add into the content panes so that it does not expand the widths. Thanks,
DotNetNuke Video Tutorials
The Skinning Toolkit
DotNetNuke Podcasts
Twitter:
www.twitter.com/DNNCreative
Minh
07/01/2008 3:14 PM
Hi Lee,
Thanks. I guess my question was really, how do I force the width to be 200px even if the image in text/html module is 250px and not expand to fit the image?
07/02/2008 3:29 AM
ok, I've just spent a while testing various elements in the default DNN Blue skin with DNN 4.8.4
If an image is larger that the width, there is no method for not allowing it to expand the width of the content pane.
However, it is possible to get the Titles to wrap.
The problem is with how the DNN Blue Container has been set up.
Open: Image Header - Color Background.ascx
look for this line:
< TD valign="middle" width="100%" nowrap > < dnn:TITLE runat="server" id="dnnTITLE" / >< / TD >
remove nowrap
This will allow the titles to wrap to the correct width
Also I noticed that I could not set the correct widths for the content panes, this is also caused by the container, look for the last line:
< img src="< % =SkinPath % >spacer.gif" height="10" width="150" border="0" >
Delete this line as it forces all containers to have a min width of 150px
Then to resize the width of the content panes, look in the skin.css file for:
.leftpane{
width: 50px;
padding-left: 6px;
padding-right: 4px;
padding-top: 6px;
.contentpane {
width: 100%;
padding-left: 6px;
padding-right: 4px;
padding-top: 6px;
.rightpane {
width: 50px;
padding-left: 6px;
padding-right: 4px;
padding-top: 6px;
Here you can see on the left and right panes I have reduced the width to 50px
Hope this helps, thanks,
DotNetNuke Podcasts
Twitter:
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
Skinning Toolkit
Skinning Toolkit
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
