Hi lee,
I am a new subscriber to your website tutorials and I am very excited about learning all these new aspects of the DotNetNuke. I am currently using 4.x and is up and running though I think the installations is not at its best in other words I think I should reinstall it to its perfection. (which I think is impossible)
I am currently working through the tutorials and ran in to some problems first (part 6 How to create a skin for dotnetnuke) I encounter a blank page after appending /install/install.aspx?mode=InstallResource to my localhost url. I then follow the the video tutorial and stopped at the point were I did not see the vortex 1 Pane – Fixed Width pages skin in the dropdown listbox (Advance setting -> Page skin)
However I did find a different way by uploading the file through host->skin-> and choosing the vortex 1 Pane – Fixed Width skins dropdown listbox .
Why cant I do this through host but only through site?
I would prefer doing it the way your tutorial/video explains
Another thing I am actually using my default website to build these tutorials.
I hope this is enough information.
