tag.
Does anyone have any experience with this?
Daniel
06/05/2008 3:04 AM | |
Hello, It maybe worth looking at the Simple Red Leaf skin, this skin has a piece of Javascript inside the skin code, thanks, |
Lee Sykes Site Administrator Subscribe to the website : DotNetNuke Video Tutorials : The Skinning Toolkit : DotNetNuke Podcasts Twitter: www.twitter.com/DNNCreative |
08/05/2008 3:30 PM | |
how to add javascript to my Skins ? |
08/07/2008 1:58 PM | |
See the tutorial to which Lee referred. |
You are not authorized to post a reply. |
Can you Run Xcode in Linux? by Aman Singh |
Can you Run Xcode in Linux? |
Billed for subscription that was canceled by Ryan |
I was just billed for a subscription that was canc eled / inactivetive how do I get a refund for th |
Meta Title and Meta Description are not showing properly by DNN User |
Hi, On my site the meta title and meta descriptions are not showing properly. It's showing the m |
Search is not functioning properly by DNN User |
Site: https://www.prv-engineering.co.uk/search If I search any item only the 1st option under sea |
DNN Platform import site optio by Melanie Weaver |
Is it possible to import site template in DNN Platform 8.0? We have internal Evoq Content 8.1 tha |
Events Module for DNN V5? by Tugboat |
Would anyone have a download link for the version 5.0.3 Events Module? Thanks! |
"Ghost" TabID Number? by Tugboat |
Hi! I have a portal instance with multiple child portals and on one of the child portals, there i |
RE: DNN Load Testing by ayman sharkawy |
Hi. Have you already implemented a site using the DNN . And how the performance of the site and its |
Publish All Pages by NSUOK |
I'm using DNN Evoq Content Basic 8.2.0. When I make the HTML Pro module display on all pages, I h |
Simpler profile needed in 9.2.2 by Donald |
We are upgrading a DNN 4.8.4 site to DNN 9.2.2. On 4.8.4, the top bar shows the user’s name. If yo |
How to link from dnnmodal popup to web site page? by Donald |
Hello all. I am using a dnnmodal.show popup. The popup works correctly, showing the content that I |
RE: Document Collaboration by Nick Davern |
That feature would be super beneficial for our needs as well! Does anyone have an update as to if th |
RE: DNN 9.2, how to set default theme? by Andy Stephenson DNN Creative |
you do that under "Manage/Themes". Note the highlight blue border around the default container and d |
DNN 9.2, how to set default theme? by Donald |
Please disregard, found Manage Themes I cannot find how to set a default portal theme in DNN 9.2 |
RE: Looking for DataSprings Dynamic Forms by Andy Stephenson DNN Creative |
Your best chance would be to contact Chad Nash @ http://www.datasprings.com/ |
Looking for DataSprings Dynamic Forms by Jakir HM |
Looking for DataSprings Dynamic Forms 3.4 for DNN 4.x 5.x for my site (https://themasters2018s.com/) |
RE: Help with Cycle Image Carousel not displaying images by peter |
I had the same problem with the Will Strohl Content Slider after upgrading to DNN 9.1 The above an |
RE: Object reference not set to an instance of an object by Andy Stephenson DNN Creative |
Check this one might be useful: http://www.dnnsoftware.com/answers/im-tryin-to-move-my-site-to-pr |
