Subject: Venexus Search Modules?
07 Mar 2008 12:15 PM
Have anyone used the Venexus modules?  If so, do you have any comments?
19 May 2008 6:51 AM
Just to follow up, Bo posted some info on Venexus search here
DrakenKorin
21 Aug 2008 4:53 AM
I've used Venexus search and Venexus tag cloud. I had to remove it a week later, as it slowed down my site drastically. I read the post mentioned above, they reccomend 512M Ram, our server has over 2 Gigs of ram and runs nothing but the DNN site and it still slowed the site down.
xfernal
21 Aug 2008 8:00 AM
DrakenKorin,
The only way it could slow down your site drastically is if it was not configured properly. We have many large sites running our modules without incident. For example, here is a site with over 500,000 items indexed and the site renders quickly (http://imvivo.com). If you were having trouble with your site, why did you not contact us for support? Our team is there to help, but we cannot help if you do not let us know there is a problem (http://support.venexus.com).
Forums > DotNetNuke® > Modules > Venexus Search Modules?
