Subject: vendor - banner/ads mod - rollover effect
thebottgroup
19 Sep 2007 1:39 PM
One of the most used modules on the sites I build is the banner/vendors one. I would however like to know if instead of the one banner picture you upload -  if there was a way to make it a rollover banner? Is there a add on module? can this be coded to do this?
19 Sep 2007 9:12 PM
You can see Lee's discussion of the ad module use on this site here.
thebottgroup
20 Sep 2007 11:10 AM
Thanks - I saw that discussion before I posted, it seem to be talking about rotating the bannner, not creating a roll-over banner, I would like to have the banner picture when hoover over to change like here
http://www.cpomilwaukee.com/
hoover over the "free v28" banner
thanks
21 Sep 2007 3:15 AM
I checked the site but couldn't see any banner that reacted to rollover. - But, to answer your question, as far as I know there isn't this facility in any of the current DotNetNuke banner modules.  However, have you tried creating a flash banner that reacts when you hover over the flash ad?  The banners modules do allow you to add flash banner advertisments.
thebottgroup
29 Sep 2007 10:23 AM
Hi Lee  - went through the videos again - I didn't see where to upload the flash file - do I go to "Add banner" then just point it to the swf file?
01 Oct 2007 1:36 PM
Yes just follow the same method as adding a GIF banner, thanks,
tiram
30 Jun 2008 1:00 PM
Hi, I had the same problem and following the Gif instruction for a flash vendor banner did not work. I keep getting "Movie not loaded" message in the flash place holder.
Any idea?
Yehuda
DrakenKorin
21 Aug 2008 4:48 AM
Did you check to make sure that you are able to upload flash files? If you go to Host -> Host settings -> Other settings, you will notice an area where you can define the files extensions that is allowed to be uploaded.
Forums > DotNetNuke® > Modules > vendor - banner/ads mod - rollover effect
Want to Upgrade from 4.4.0 to lastest DNN by napsoc.org
I'm a intermediate user of DNN and our org's "web manager." We're currently using DNN 4.4.0. Are the...
MMLinks module by Absinte
I am using the MMLinks module on a tri-lingual website. When i insert a picture in the HTML text pro...
RE: Change Skin on URL by rdickey
We are looking for something simular. We have some modules that like to display the admin skin when...
Changing "Register" to "Sign up" by evo
HiI recently started using DNN for my programming needs (I have been programming in ASP for the last...
