Hi Lee
A question regarding the FCK editor.
When associating it with the skin.css file, (enabling the dynamic button) the text area takes the colour of the background specified in the body class.
The background colour I am currently using is black, which makes it very difficult to see the text. I took the advice from your tips forum from webbo who suggested to add another body class and associate the colour to that. However, I have found that this does not have the same full effect as the original body class .
I understand that within the FCK editor is a file called editorarea.css which I believe will effect the background of the edit area as the name implies. However, I am not too clear how I can use this, i.e. if I should move it or edit it and can I still use the styles from my skin.css, I am a little confused.
Thanks.
Lynn
