Subject: News Feeds (RSS) module 4.0 ?
wolmar
27 Aug 2008 8:56 AM
I had some trouble with the old NewsFeeds module (the one coverd in tutorial) so i figured i'd install the latest version. Problem is now i can't fint where to point to my XSL file to get the right formating. Any ideas?
 cheers
  /martin
28 Aug 2008 2:59 AM
It works in exactly the same way. Go to 'edit newsfeed' - enter the RSS URL for the newsfeed source - news feed stylesheet, click on upload new file, upload the xsl stylesheet you wish.
make sure you view both of these tutorials:
Forums > DotNetNuke® > Modules > News Feeds (RSS) module 4.0 ?
