Subject: Deeper in Sidemenu
jaya
25 Aug 2008 6:21 PM
I'm trying to get CISS.SideMenu  (in a 4.o install) to allow more than 3 levels deep in the side menu.  We've tried changing the setting to 4 or 5, but it changes back.  What are we missing?
26 Aug 2008 7:38 AM
I don't have any experience with that menu. Have you inquired of the developer?
Forums > DotNetNuke® > Modules > Deeper in Sidemenu
