Subject: Accordion
LearnDNN
21 Aug 2008 2:45 PM
Hi guys,
 am trying to create a Accordion links as a module, to add anywhere i want. Is there any inbuilt feature for dotnetnuke, or else can anyone please give a heads up to how to go about making it...
Waiting for a response...
LearnDNN
25 Aug 2008 10:01 AM
Please people give out a response in regards to the accordion module.
I have to make a sliding menu as well , like the main menu items bar should have an arrow or button named more on clicking which the bar should have more new menu items.
please help me out.
26 Aug 2008 7:41 AM
If you will Google "dotnetnuke accordion menu" then you'll find a number of references. I don't have any experience with any of them, so I can't make a recommendation.
LearnDNN
02 Sep 2008 3:13 PM
Thanks for the reply joe
Well i did that , i would like to get an idea if anyone implemented the accordion module.
I also needed to have sliding menu, like if there is an arrow image button in the menu bar and i click that the current set of menu items should be replaced by next consecutive set of menu items. I hope you got wat i meant.
Well any ideas of working that out, please let me know....
thanks
02 Sep 2008 8:09 PM
I thought that one of the links I found pointed to a menu module on Snowcovered. You might want to search there.
04 Sep 2008 3:53 AM
This page on snowcovered has an example of an accordion menu module.
Forums > DotNetNuke® > Modules > Accordion
Want to Upgrade from 4.4.0 to lastest DNN by napsoc.org
I'm a intermediate user of DNN and our org's "web manager." We're currently using DNN 4.4.0. Are the...
MMLinks module by Absinte
I am using the MMLinks module on a tri-lingual website. When i insert a picture in the HTML text pro...
RE: Change Skin on URL by rdickey
We are looking for something simular. We have some modules that like to display the admin skin when...
Changing "Register" to "Sign up" by evo
HiI recently started using DNN for my programming needs (I have been programming in ASP for the last...
