Subject: Repository template: YouTube
BluesmanMedia
13 Aug 2008 2:44 PM
Hey Guys,
Does anyone have access to the YouTube template for the repository?  I've been asking in the DNN forums but have received no replies do date, not even from the repository project people themselves.
There are several threads there (dnn site) that refer to the template and even discuss modifications but I cannot find the template anywhere.  It is not in the repository module download either.
There was a pointer in a thread from Steve Fabian, but the link does not work.
Any help/suggestions would appreciated.
thanks,
Rocco
They call it "engineering" because it's just like driving a train off a cliff.
BluesmanMedia
16 Aug 2008 12:10 PM
Found it!   Received a reply at DNN and the Youtube template is now available if anyone needs it.
http://www.dotnetnuke.com/Community/Forums/tabid/795/forumid/54/threadid/248074/scope/posts/Default.aspx
- rock
18 Aug 2008 3:08 AM
great, thanks for posting the info,
bryan_homey
22 Aug 2008 10:36 AM
So How do I apply the YouTube template to the Repository Module?
Bryan
24 Aug 2008 9:22 PM
You need to create a directory in DesktopModules\Repository/Templates and then put the template files in that directory. Then, you need to go to the Repository Module's settings. The new template should appear in the list of available templates.
bryan_homey
27 Aug 2008 4:27 PM
Forums > DotNetNuke® > Modules > Repository template: YouTube
Want to Upgrade from 4.4.0 to lastest DNN by napsoc.org
I'm a intermediate user of DNN and our org's "web manager." We're currently using DNN 4.4.0. Are the...
MMLinks module by Absinte
I am using the MMLinks module on a tri-lingual website. When i insert a picture in the HTML text pro...
RE: Change Skin on URL by rdickey
We are looking for something simular. We have some modules that like to display the admin skin when...
Changing "Register" to "Sign up" by evo
HiI recently started using DNN for my programming needs (I have been programming in ASP for the last...
