Subject: UDT Module and Hiding Columns
cschollie
04 Aug 2008 8:02 PM
Am working with the UDT module for the first time and find it very useful.
Have one module displayed on two different pages with row filtering. Works great!
Is there some way to have different columns show up on each page? Seems hiding a column hides it on both pages. I want to hide different columns on the two different pages. Is this possible?
Thanks in advance.
Cheers,
Corinne
07 Aug 2008 3:59 AM
Yes you can, but you do this with the display settings rather than the visible tick box.
In your 2nd copy, go to manage table /  display settings (for current page) - select  'User Defined XSL Transformation'  from there you can specify a template for the display and choose which columns to display.
For more info checkout:
User Defined Table (UDT) DotNetNuke Core Module
especially videos 6 - 9
Forums > DotNetNuke® > Modules > UDT Module and Hiding Columns
