Subject: Custom CSS for the Text/HTML Module?
digitaldoom
04 Aug 2008 4:49 PM
Is there a way I can add a custom CSS class to the Text/HTML Module?
I have a few formatting changes I would like to make, but only to the Text/HTML Module.
I did find some places in CSS to change stuff, but it changed the content of every module.
... Help
04 Aug 2008 9:57 PM
The easiest way (at least the way that I like to do it) is by wrapping the specific module with a div tag. You can do this in the module's header and footer.
Header: < div id="myID" >
Footer: < /div >
Then, you can add styles for myID in skin.css. You can also stick them in the header, ahead of the div tags using style tags.
digitaldoom
05 Aug 2008 1:07 PM
Posted By jncraig on 04 Aug 2008 9:57 PM
Footer: < /div >
this is a great solution, thanks!
Forums > DotNetNuke® > Modules > Custom CSS for the Text/HTML Module?
