Subject: Filemanager-change folder names
yokogawahq
29 Jul 2008 6:57 AM
In our company we are using DNN for our Intranet and Extranet. There are often organizational changes, which are rather easy to modify on our Intranet, for example Quality becomes QHSE.
However the underlying foldername of the documents in the filemanager is still called Quality
I would like to know if it's possible to change the foldernames in filemanager without changing all links on the QHSE pages and subpages manually.
Anyone?
Regards,
Bart
29 Jul 2008 7:56 AM
If the links point to directories by name, you're going to have to change them. If they are in Text/HTML modules, a free modules like Engage's F3 might be a real help and time saver.
yokogawahq
01 Aug 2008 1:04 AM
Thank you!
Forums > DotNetNuke® > Modules > Filemanager-change folder names
