Subject: Unable to import files into Document Module
kdr0919
17 Jul 2008 1:18 PM
I'm sure I'm just missing something, but when I try to import .jpg files into my standard dnn document module, the list is blank.  I have checked the folder and file permissions in File Manager and I have tried this under both the admin and host logins.
Can someone help me pull my head out?
Kevin
17 Jul 2008 8:01 PM
Have you also made sure that .jpg is a file type that you are allowed to upload (though it seems that it would be the case).
kdr0919
17 Jul 2008 8:28 PM
Yes, I haven't changed the default there and it includes jpg files.
17 Jul 2008 8:36 PM
I just uploaded a jpg file to the documents module on my test site. No problems.
When you say that "the list is blank" ... which list?
kdr0919
17 Jul 2008 8:49 PM
The file selection list you use when you attempt to import a file into the document module.
I've attached two screenshots.  The first is my file manager.  As you can see the Newsletter folder has five .jpg files in it and the folder permissions are set to View for All Users.  The second is the import selection where you can see it is blank.
Thanks for your help.
Kevin
17 Jul 2008 9:07 PM
There's nothing like a good screen shot or two to help the understanding.
You've added files via the File Manager, and now you want to make these available in the Documents Module. What you want to do is "Add a Document" using the Document Module's dropdown menu. Then you fill in the form to describe the document and you select the file using the two dropdown boxes labelled "Link." When you are done, click "Update" at the bottom. Note that you also have the option to upload new files right here, rather than in the File Manager.
kdr0919
17 Jul 2008 9:13 PM
Ah, okay that makes sense.  I told you somebody needed to help my pull my head out!
So, what is the "import content" for?
Kevin
17 Jul 2008 9:48 PM
Export and Import are operations by which you can Export all of the content of a module into an XML file. That can then be used to Import the same data into an empty module of the same sort.
kdr0919
17 Jul 2008 10:01 PM
Okay, thanks so much for you help!
Forums > DotNetNuke® > Modules > Unable to import files into Document Module
Want to Upgrade from 4.4.0 to lastest DNN by napsoc.org
I'm a intermediate user of DNN and our org's "web manager." We're currently using DNN 4.4.0. Are the...
MMLinks module by Absinte
I am using the MMLinks module on a tri-lingual website. When i insert a picture in the HTML text pro...
RE: Change Skin on URL by rdickey
We are looking for something simular. We have some modules that like to display the admin skin when...
Changing "Register" to "Sign up" by evo
HiI recently started using DNN for my programming needs (I have been programming in ASP for the last...
