Subject:  dotnetnuke modules interaction
botcode
09 Jul 2008 6:05 AM
        I am facing the problem with module interaction in dotnetnuke.can any one tell me how to interacte modules which is  on differente pages.
Such as we have two pages and modules  one is search and another is searchresult page ,so if some one click on search button then it shows the result on the searchresult  module with search page condition and show the resullt in grid with link in that and if some one click on tha its goes to the detail page which again on different page.
for example you can go through site  http://mydiscovercareer.com
here you can find a search module and when u search it goes to next page with result with links in gridview (maybe.)and againif click on that link it goes to next page there u can see different buttons.i want same type of module interaction in dotnetnuke.
can anyone help me
12 Jul 2008 9:08 AM
I don't believe that you can use in intermodule communications facilities in DotNetNuke to communicate across pages. For that I would use session variables. If you are always going directly from one page to another, you could use a query string to pass short lists of parameters. You could also use form post to send larger amounts of data.
Since you are speaking of search, you might want to do some analysis of how the DotNetNuke search works.
Forums > DotNetNuke® > Modules > dotnetnuke modules interaction
