Subject: Alternatives to the events module
mtarby
08 Jul 2008 2:27 PM
I've been looking around the site, but couldn't find any module reviews that talked about alternatives to the DNN events module.
Does anyone have any product recommendations?
Specificially, we're looking to be able to offer people the ability to click on an event and rsvp directly from there.
Any suggestions would be most appreciated!
12 Jul 2008 9:08 AM
Suggestions, anyone?
15 Jul 2008 6:12 AM
from a quick search on Snowcovered, I found a few modules which may suit, in particular the smart-thinker module.
Forums > DotNetNuke® > Modules > Alternatives to the events module
