Subject: DNN Article Module
cclausen
08 Jul 2008 10:06 AM
We are using DNN Article module to list our podcasts. We add the podcasts in there and it can be listened to when you click on the link. It is also being sydicated through XML Feed. I want to setup a feed that everytime a podcast is uploaded and gets listed on the website, it automatically updates it in iTunes so user can listen to it through iTunes store without having to com to our website. Any idea how I can do this? I would really appreciate your help.
10 Jul 2008 1:53 PM
I'm not sure how iTunes works, but you may want to look at the  facilities from feedburner.com - feedburner allows you to add your RSS feed, create a new feedburner feed from it and feedburner will automatically manipulate the feed to be suitable fo r a variety of aggregators, including podcasts - so this maybe the solution, let us know how you get on, thanks,
Forums > DotNetNuke® > Modules > DNN Article Module
Want to Upgrade from 4.4.0 to lastest DNN by napsoc.org
I'm a intermediate user of DNN and our org's "web manager." We're currently using DNN 4.4.0. Are the...
MMLinks module by Absinte
I am using the MMLinks module on a tri-lingual website. When i insert a picture in the HTML text pro...
RE: Change Skin on URL by rdickey
We are looking for something simular. We have some modules that like to display the admin skin when...
Changing "Register" to "Sign up" by evo
HiI recently started using DNN for my programming needs (I have been programming in ASP for the last...
