Subject: XML Module
mtarby
13 May 2008 10:38 AM
I'm trying to get a sense if I'm on the right track or not.  I'm using the XML/XSL module to display my data.  But now I'm wondering what is the best way to allow administrators to edit the data within the XML file.
Is there a third party module that will give that control?  Should I try to develop my own module?  Or use the UDT module?  Something I haven't thought of yet?
Any suggestions would be most appreciated!
Forums > DotNetNuke® > Modules > XML Module
RE: GoDaddy by greenflash
RE: GoDaddy by aggiedan97
