Subject: House of Nuke + Language Locale
sabram
08 May 2008 4:40 PM
Hi! I want my users to be able to choose their language on my site. I have installed several language packs on my site and it works in with DNN Blue and solpartmenu. However, I want to use another skin and it uses the House of Nuke menu.
I cut the code from the DNN blue into the new skin ascx file but I don't get it to work. Why?
It says:
Could Not Load Skin: /Portals/_default/Skins/newskin/index.ascx Error: Unknown server tag 'dnn:LANGUAGE'.
What do I do to get it to work? Big thanks. I appriciate everyone that can help me.
S. R.
Nuke Master I
Nuke Master I
08 May 2008 7:19 PM
I'd guess that you've left out some definitions at the top of the skin file. Compare the skin with the DNN skin.
Forums > DotNetNuke® > Modules > House of Nuke + Language Locale
RE: GoDaddy by greenflash
RE: GoDaddy by aggiedan97
