You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
DotNetNuke®
DotNetNuke® Questions
Domain in Address Bar
Last Post 03/01/2008 10:37 PM by
Stu
. 8 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Rich Howard
04/13/2007 3:02 PM
My site (www.assisisoft.com) comes up as "assisisoft1.web144.discountasp.net".
How do I get it to come up as my domain (www.assisisoft.com)?
Is this an ISP hosting question or a DNN question?
Rich
04/16/2007 9:21 AM
This is probably a bit of both. Go to the admin menu / site settings
scroll down to PortalSettings
is your domain listed here?
If not add your domain name as a portal alias (do not include http://)
Then ensure that your domain name points to your DotNetNuke installation with your domain names DNS settings.
If you are still having problems than it would be worth contacting your hosting provider to see if they can provide any tips.
Hope this helps,
DotNetNuke Video Tutorials
The Skinning Toolkit
DotNetNuke Podcasts
Twitter:
www.twitter.com/DNNCreative
Rich Howard
04/16/2007 11:52 AM
Thanks. I've never seen that setting. Never scrolled down far enough I guess.
Now I've got:
HTTP Alias
assisisoft1.web144.discountasp.net/dnn
www.assisisoft.com
What is the meaing of the first alias? Should it be deleted? How? It is the one that is still showing up in the adress bar.
Is there more indepth docs on this (and related issues) on the web somewhere?
Rich
04/16/2007 12:02 PM
You can only delete that alias when you are viewing your portal with the domain name of www.assisisoft.com
- when you do that you will find there is a pencil icon next to this domain name
I would speak to your hosting provider to enquire why it is forwarding to
assisisoft1.web144.discountasp.net/dnn when you enter
www.assisisoft.com
DotNetNuke Podcasts
Twitter:
Rich Howard
04/16/2007 3:50 PM
My host is saying this is a coding issue and shutting off my requests. This is DiscountASP by the way.
I first set up DNN when all I had was temp site access (assisisoft1.web144.discountasp.net). So DNN must have set all its internal references to that site address. It's supposed to disappear after going live, which I take to mean switching to their DNS servers. I am on their DNS servers and www.assisisoft.com resolves fine. But it looks to me that their servers are internally forward to the temp site.
I know this sounds outside of DNN, but is it correct that what should happen is www.assisisoft.com should resolve directory to the web site directory and the temp site be deleted?
Or is it that DNN has the temp site address stored in too many places to change now? I would think that the Portal Settings is the one place that says, prepend this address "www.assisisoft.com" to the start of all requests. If so, then it is still an ISP problem.
Rich
Rich Howard
04/16/2007 4:07 PM
Wait, Isn't this a DNN issue after all? Isn't DNN prepending the "assisisoft1.web144.discountasp.net" onto the requests? No matter how you access "default.aspx" it comes back with "assisisoft1.web144.discountasp.net" prepended because DNN prepends it. No?
Rich
Rich Howard
04/16/2007 10:53 PM
ANSWER. Yes its a DOtNetNuke issue:
You have to enter a Portal Alias in DotNetNuke that has the full domain path to your DotNetNuke install directory. A simple forwarding page in the root is not sufficient.
Enter a Portal Alias on the Site Settings page that looks like this: "www.mydomain.com/dnn" where dnn is the dotnetnuke install directory.
Do this and create a forward command in your default root page. Mine has "Response.Redirect("/DNN/Default.aspx");" in default.aspx.vb.
Jesus, someone please doc this stuff better!
Rich
04/17/2007 2:03 AM
Thanks for the info Rich
DotNetNuke Podcasts
Twitter:
Stu
03/01/2008 10:37 PM
Ok I'm Tech Support for a hosting company. we recently got the ability to do DNN on our windows platforms. Working with it I have had the problem of re pointing my DNN package to my new domain. I went threw the steps of setting it up int he portal section and then I can across Rich's post as to how he got it to work (thanks Rich) but now I don't see the template body and when i click login it just takes me to the site with the temp domain i assigned. I know this isn't Issue with the domain pointer on the side of my host provider. Any suggestions?
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
DotNetNuke®
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
