You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
DotNetNuke®
DotNetNuke® Questions
Text heading are missing in DNN5.1.4 (on second parent portal)
Last Post 03/02/2010 11:08 AM by
. 10 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Dush
11/28/2009 6:27 AM
I have installed DNN 5.1.4 and created an additional parent portal. But after login in to that portal as the administrator, some of the Text headings disappeared. I tried reinstalling 3 times but it didn’t fix. I am hosting My site at GoDaddy Deluxe web hosting plan. Initially I used the GoDaddy installation script to install 5.1.2 and with that installation after login in as the super user almost all the text heading disappeared. Then I uninstall and re-installed but no luck. Then I downloaded the 5.1.4 and installed it manually. And login to the host and everything was OK. Then I created another parent portal, and login to this new portal as portal administrator. Then the problem appeared again. Ie. Text names of control panel, logout text, Terms and Condition text from the front page, and lot more text headings are missing. Can someone please help me ?
DNN MVP
11/28/2009 9:32 AM
And text appears correctly in the other portal?
Check to make sure that the default language is specified for this portal.
Joe Craig,
Patapsco Research Group
Complete DNN Support
Dush
11/28/2009 4:03 PM
Thanks Joe,
Yes. The only other portal is the main host portal, text appears correctly in it. In both portals I use Australian Locale(English) and configured the currency to AUD.
DNN MVP
11/28/2009 8:21 PM
If might be interesting to create a third portal and see which behavior it exhibits.
Joe Craig,
Dush
11/28/2009 11:37 PM
I created the 3rd portal, same result as the second, no text headings.
DNN MVP
11/29/2009 5:21 PM
I don't have any ideas about this one ...
Joe Craig,
Lavi
12/10/2009 8:45 PM
Having the same problem.
Have you had any luck with this issue?
Dush
12/11/2009 3:09 AM
No. I installed same version for another customer on their own Windows 2003 based web server and configured 2 sites. It worked well. I think this problem is only with goDaddy.com hosting. They are not realy a good windows provider, they have stupid limitations and requirements. If you are using GoDaddy, My best advice is to find a good windows hosting provider.
CBOSS INC
02/25/2010 11:24 AM
I have the same issue. I just recently did an upgrade, however no errors and portal was fine after upgrade. Now I see the same thing as your image above. I do not host with Go Daddy, we host our own web server. Any other suggestions? Were you utilizing any third party modules like page localization for multilingual?
Dush
02/26/2010 5:26 AM
No I didn't use any 3rd party modules. But I change the locale to Australian settings. Now I am hosting the site with a different provider and it works well. Try upgrading to latest version.
03/02/2010 11:08 AM
CBOSS, did you check that a default language is still set after the upgrade?
Try this:
Go to ADMIN menu - LANGUAGES
Under Available Locales if your Langauge is not selected, click the dropdown and select the language
Select Edit Language and then
Select Enabled
Now if you go ADMIN - SITE SETTINGS - Advanced Settings - Other Settings - Default Language (Should be correct)
source:
http://www.dotnetnuke.com/Community...fault.aspx
DotNetNuke Video Tutorials
The Skinning Toolkit
DotNetNuke Podcasts
Twitter:
www.twitter.com/DNNCreative
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
DotNetNuke®
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
