dear joe
can u tell me is this default.aspx and home.aspx pages same or not...
in my iis documents tab default.aspx page only...
but when i type home.aspx it is giving me the home page...
from iis when i right click default.aspx page and click browse getting same home page...
is this home and default page is same or not???????????
in iis i didnt find out any home.aspx page...
based on ur opinion my portalalias is www.afticom.com:8000 only
errors getting stated as follows...so again i added www.afticom.com
in aliases...otherwise my web is not working...i am thinking some page sttings is required somewhere...can u guide me 4 solving this issue..........
now my portal aliases are
www.afticom.com
when login www.afticom.com:8000 not possible to edit...if i delete www.afticom.com
web is not coming
after removing the two aliases my problems is as follows.....
http://www.afticom.com:8000/home.aspx" target="_blank" rel="nofollow">
http://www.afticom.com:8000/home.aspx --->i tried this link getting error like
Server Error in '/' Application.
The resource cannot be found.
Description: HTTP 404. The resource you are looking for (or one of its dependencies) could have been removed, had its name changed, or is temporarily unavailable. Please review the following URL and make sure that it is spelled correctly.
Requested URL: /home.aspx
then itried like
http://www.afticom.com:8000/ getting error like
The page cannot be displayed
The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings.
Please try the following:
Click the Refresh button, or try again later.
If you typed the page address in the Address bar, make sure that it is spelled correctly.
To check your connection settings, click the Tools menu, and then click Internet Options. On the Connections tab, click Settings. The settings should match those provided by your local area network (LAN) administrator or Internet service provider (ISP).
See if your Internet connection settings are being detected. You can set Microsoft Windows to examine your network and automatically discover network connection settings (if your network administrator has enabled this setting).
Click the Tools menu, and then click Internet Options.
On the Connections tab, click LAN Settings.
Select Automatically detect settings, and then click OK.
Some sites require 128-bit connection security. Click the Help menu and then click About Internet Explorer to determine what strength security you have installed.
If you are trying to reach a secure site, make sure your Security settings can support it. Click the Tools menu, and then click Internet Options. On the Advanced tab, scroll to the Security section and check settings for SSL 2.0, SSL 3.0, TLS 1.0, PCT 1.0.
Click the Back button to try another link.
Cannot find server or DNS Error
Internet Explorer
