You need to
Register
for free and
Forums
Search Forum
Advanced Search
Topics
Posts
Unanswered
Active Topics
Forums
DotNetNuke®
DotNetNuke® Questions
Someone rescue me! Critical Exception in DNN 4.5.5
Last Post 11/20/2007 9:00 AM by
. 5 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
angrygerbil
11/19/2007 1:47 PM
I have only standard controls on the main page of my site. For certain users, sporadically, it's blowing up when they try to log in. I have seen others have this problem but nobody ever seems to reply or even look into it. Help?! Once users get into this state, it seems to be permanent until they delete their cookies and temporary files. This makes me think it's possibly a caching issue?
My Performance Settings Are:
Page state persistence:
Page
Module Caching Method:
Disk
Performance Setting:
Light Caching
Authenticated Cacheability:
Public
Compression Seetings:
Deflate Compression
Has anyone else run into this? What was the resolution or the problem you found that caused it!?
A critical error has occurred.
DotNetNuke.Services.Exceptions.PageLoadException: Failed to load viewstate. The control tree into which viewstate is being loaded must match the control tree that was used to save viewstate during the previous request. For example, when adding controls dynamically, the controls added during a post-back must match the type and position of the controls added during the initial request. --->
System.Web.HttpException: Failed to load viewstate. The control tree into which viewstate is being loaded must match the control tree that was used to save viewstate during the previous request. For example, when adding controls dynamically, the controls added during a post-back must match the type and position of the controls added during the initial request. at System.Web.UI.Control.LoadViewStateRecursive(Object savedState) at System.Web.UI.Control.LoadChildViewStateByIndex(ArrayList childState) at System.Web.UI.Control.LoadViewStateRecursive(Object savedState) at System.Web.UI.Control.LoadChildViewStateByIndex(ArrayList childState) at System.Web.UI.Control.LoadViewStateRecursive(Object savedState) at System.Web.UI.Control.LoadChildViewStateByIndex(ArrayList childState) at System.Web.UI.Control.LoadViewStateRecursive(Object savedState) at System.Web.UI.Control.LoadChildViewStateByIndex(ArrayList childState) at System.Web.UI.Control.LoadViewStateRecursive(Object savedState) at System.Web.UI.Control.LoadChildViewStateByIndex(ArrayList childState) at System.Web.UI.Control.LoadViewStateRecursive(Object savedState) at System.Web.UI.Control.LoadChildViewStateByIndex(ArrayList childState) at System.Web.UI.Control.LoadViewStateRecursive(Object savedState) at System.Web.UI.Control.LoadChildViewStateByIndex(ArrayList childState) at System.Web.UI.Control.LoadViewStateRecursive(Object savedState) at System.Web.UI.Page.LoadAllState() at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) --- End of inner exception stack trace ---
DNN MVP
11/19/2007 2:01 PM
Most often, I've seen this when user's session has timed out. The "session state" then no longer matches the current one. I don't believe that it is a caching issue, but it is a cookie issue.
Hopefully someone else has some ideas.
Joe Craig,
Patapsco Research Group
Complete DNN Support
angrygerbil
11/19/2007 3:17 PM
What settings do I need to change to increase the users session so it won't happen again? Having this come up a lot and expecting them to delete their cookies is unfortunately not going to cut it for any of us running a DNN site. Did you have any luck resolving it?
DNN MVP
11/19/2007 6:14 PM
Here are some other things that probably are more important to timeout issues.
Do you have anything non-standard in your installation?
Do you have compression enabled in IIS? If you do, try disabling it.
Also, have you been playing with the performance variables available under Host Settings? If so, you should set Page State Persistence to Page and not Memory.
Here are John Mitchell's (snapsis.com) recommendations for DotNetNuke settings. I'd use them!
Page State Persistence: Page
You could try memory, but I believe there are too many problems here without much gain especially as a global setting.
Module Caching Method: Memory
Memory is much faster, and there are intermittent errors when using Disk.
Performance Setting: Heavy
There is really not much difference between the different settings here. The setting is just a multiplier that gives you only 5 hours of caching at the most (depending on the object) when on Heavy. Some items are not cached at all unless you are on Heavy.
Authenticated Cacheability: Set it to public.
This allows the client browser or downstream proxies to cache items.
Compression Setting: Deflate or Gzip does not matter.
They are both about the same and will vary depending on content. I use Gzip.
Compression Level: There is a bug that is keeping it from being applied, but it should be around five, higher than that gives diminishing return.
Use Whitespace Filter: Not Checked
Don't use it if you have compression on it is a waste of time, because compression also removes white space.
Joe Craig,
angrygerbil
11/19/2007 7:52 PM
Joe,
Thanks for the reply. I've checked my settings and they are all set to that except for the performance setting. I am currently having the site hosted on Sever Intellect and on Shared server. This undoubtedly means they have throttled both cpu and memory usage. I am unsure what happens to the ASP.NET worker process when the memory consumption exceeds the throttling, but I suspect it might be a bad thing. What are your thoughts on that matter?
Are there also
web.config
settings that can cause problems with the sessions and cookies? There are all sorts of settings that appear to be strewn all over the place in there. I can't seem to dig up good information on the following items for example:
EnableCachePersistence
PersistentCookieTimeout
Forms
httpCookies
anonymousIdentification
Here are those settings as well:
<form>s name=".DOTNETNUKE" protection="All" timeout="60" cookieless="UseCookies"/>
DNN MVP
11/20/2007 9:00 AM
Change the performance settings in DotNetNuke and see if that helps.
Joe Craig,
Special Bonuses
--Subscriber Bonuses
--Readers Offers
Users Lounge
--Announcements
--DNN Creative Articles
--Everything Else
--Membership
--Site Review Please!
--Testimonials
--Podcasts
DotNetNuke®
--DotNetNuke® Questions
--Modules
--Modules - What's needed?
--Quick Tips
Hosting
Skinning Toolkit
--Skinning Toolkit
UK DotNetNuke User Group
Forums
DotNetNuke®
Can you Run Xcode in Linux?
by Aman Singh
by Aman Singh
by Ryan
by DNN User
by DNN User
by DNN User
by Melanie Weaver
Events Module for DNN V5?
by Tugboat
"Ghost" TabID Number?
by Tugboat
RE: DNN Load Testing
by ayman sharkawy
Publish All Pages
by NSUOK
by Donald
by Donald
RE: Document Collaboration
by Nick Davern
by Donald
by Jakir HM
by peter
