Phil
 Nuke Newbie Posts:2
12/14/2009 7:36 AM |
Im having a problem where an example html page will display perfectly
with a container height the size of the page, however this does not
appear to work in my DNN page, all of the div's are named exacty the
same, any ideas how i can get my content div to fill any remaining
space on the page? my template skin ascx http://pastebin.com/f4db76b70The css example http://www.xs4all.nl/~peterned/examples/css/layout1.css Edit Solved:
Had to add form{ height:100% } to deal with the container generated by the dnn content |
Lee Sykes DNN Creative Staff
 Nuke Master VI Posts:4945
Anthony
 Nuke Pro Posts:72
05/14/2010 5:02 AM |
Hi, I have the same problem. The footer is not layed out at the bottom of my page. I added this css code to my skin.css file:
form{ height: 100% }
but it is not working. Am I missing something here?
greetings,
Anthony |
Anthony
 Nuke Pro Posts:72
05/17/2010 4:09 AM |
Hi Lee,
this is the website:
http://www.tandjebij.be
thanks for looking in to it,
Anthony
www.webmove.be
Belgium |
05/17/2010 1:56 PM |
Hello, Looking at your code: #footer { height:32px; font-family: Trebuchet ms, Verdana, Arial, sans-serif; font-size: 10px; color: #000; text-align: center; float: bottom; vertical-align: bottom; padding-top: 10px; margin-top: 150px; background-color: #f3f4f4; text-decoration: none; border-bottom: 1px; border-bottom-color: #fff; border-top: 1px; border-top-color: #fff; } You may want to check: margin-top: 150px; This adds the large space above the footer Also, float: bottom does not exist in CSS, you may want to try clear: both instead. We have a CSS reference book here which may help: CSS Reference Book (112 page PDF)Thanks, |
Anthony
 Nuke Pro Posts:72
05/18/2010 3:35 PM |
Thanks Lee for the advice and suggestions. I couldn't solve the problem though. The trouble is that the skin is a combination of table layout and css layout.
In Firefox everything renders normal, the problems occur only in IE : (
greetings,
Anthony |
Anthony
 Nuke Pro Posts:72
05/22/2010 8:24 AM |
Hi Lee, Seems that I got it almost right. I had to configure also the .c_content class in the skin.css for the container. I added the height: 350px;height:auto;min-height:350px; definitions to this class. The only problem I'm left with is this awkward ');' character under the footer: http://www.tandjebij.be/contact.aspxI've seen this mysterious character also appearing in the Flex2 skin from DrNuke. Is this a DotNetNuke bug? greetings and thanks for your help, Anthony www.webmove.be Belgium |
05/22/2010 9:24 AM |
Those extra characters are in your skin file.
Anthony
 Nuke Pro Posts:72
05/24/2010 1:11 PM |
I discovered that these characters come from the Google Analytics tracking code that I pasted in the 'url parameter' textbox on the Google Analytics admin page. I checked the code again for any typo's , but it is correct:
[script removed]
var _gaq = _gaq || [];
_gaq.push(['_setAccount', 'UA-10037575-7']);
_gaq.push(['_trackPageview']);
(function() {
var ga = document.createElement('script'); ga.type = 'text/javascript'; ga.async = true;
ga.src = ('https:' == document.location.protocol ? 'https://ssl' : ' http://www') + '.google-analytics.com/ga.js';
var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(ga, s);
[script removed] |
Anthony
 Nuke Pro Posts:72
05/30/2010 8:42 AM |
If that code is being injected in the page by the Google tracking code, it probably will happen with every skin.
Can you just use the tracking code and not the extra stuff?
Anthony
 Nuke Pro Posts:72
05/31/2010 8:36 AM |
Yeah, I guess so. I got confirmation from drnuke that the problem does not originate from their skin file, but is generated by the Google Analytics code.
So I'll remove that code from the url parameter textbox on the Google Analytics page. I wonder I my pages will still be tracked after this?
greetings,
Anthony
Belgium |
05/31/2010 9:19 AM |
Just put your tracking code in the Tracking ID box and that's all that you need to do.
