| How to override HTTP Module? by leadnex |
Want to know, how to override HTTP module like my http module should load before DNN's and decid... |
| RE: Issue 32 - Powerful Efficient Techniques for DotNetNuke Administration using SQL by nirpet |
| I checked it again after I saw your post.The answer is Yes. I have edited both connection strings.Ni... |
| RE: Events calendar by jncraig |
| I'll certainly take you up on the idea of a bunch of us having dinner! |
| RE: Issue 32 - Powerful Efficient Techniques for DotNetNuke Administration using SQL by jncraig |
| Just to double-check: You have edited both connection strings? |
| This is my web.config connection string:Data Source=.\SQLExpress;Initial Catalog=C:\DOTNETNUKE SITES... |
| Expanded sections (Advance settings) collapses automatically! by maxdagenais |
Recently our production DNN install (DNN 4.8.4) with 50+ portals started misbehaving
as ... |
| Changing the House Menu?? by ollep |
| Hi Lee
I can’t see sub-menu’s in some of the horizontal House Menu skins?
I recall you where... |
| RE: Pop up window by yerann |
| Thank you for the reply. Yes this is the module I was looking for. |
| RE: around every module by leesykes |
| Are you using containers? I seem to recall this prob occurs if you do not use a container. I use a t... |
| around every module by databanq |
| It seems like DNN adds a span-tag around all of my modules, and inside this tag it adds a div tag. T... |
| RE: Events calendar by leesykes |
| Would love to do that, but not going this year, it was one or the other and decided to give europe a... |
| RE: Events calendar by mgordon |
| Thanks Lee. I'll do that.On a separate note. Will you be in Vegas for the DevConnections conferenc... |
| RE: Installation of Modules Errors by leesykes |
| I would contact your hosting provider and ask them to re-enable permissions on your DNN installation... |
| RE: Issue 32 - Powerful Efficient Techniques for DotNetNuke Administration using SQL by leesykes |
| not sure, could you post you web.config connection string for your local installation? anyone else a... |
| not dnn specific, you could post a request in the forum here, or look outside of DNN on the outsourc... |
| RE: Admin upload skins? by leesykes |
| Yes the whole install section has been redone - only host will now have access for installing. Skins... |
| I have never checked that out, but maybe it's time to start doing so. Thanks Lee. Do you have any ... |
| have you tried any of the dnn job sites like dnnguru.com - I get emails often from indian developers... |
