Subject: Module menu skinning issue
dp6ai
18 Jul 2008 4:47 AM
I have an issue with my site that is driving me slightly nuts.
The menu for the modules jumps left in IE when you hover over the drop down icon.
http://rochfords.testmoss.com/testmenu.aspx
login =  testmenu
pass = testmenu
I'm not even sure how to go about debugging this as firebug etc doesnt really work on it and it works in FF anyway.
Any help would be greatly appreciated.
thanks
dp
18 Jul 2008 5:55 AM
dp6ai
18 Jul 2008 6:04 AM
I'm using blankcontainer.ascx
there's not much to it and no css:
<%@ Register TagPrefix="dnn" TagName="SOLPARTACTIONS" src="~/Admin/Containers/SolPartActions.ascx" %>
<%@ Register TagPrefix="dnn" TagName="SOLPARTACTIONS" Src="~/Admin/Containers/SolPartActions.ascx" %>
<table width="100%" border="0" cellspacing="0" cellpadding="0">
    <tr>
        <td>
            <dnn:SOLPARTACTIONS runat="server" id="dnnSOLPARTACTIONS" /></td>
    </tr>
    <tr>
        <td id="ContentPane" runat="server" valign="top">
        </td>
    </tr>
</table>
18 Jul 2008 7:24 AM
22 Jul 2008 5:05 AM
If you have set the DOC TYPE to XHTML transitional you may see these problems with the Solpart menu, have a look here for further info
Forums > DotNetNuke® > DotNetNuke® Questions > Module menu skinning issue
WOW GOLD by wowgolds987
RE: Pop up window by yerann
RE: Events calendar by mjbieg
