Subject: Showing error after changing the settings in Container
kaustav_kar
18 Jul 2008 4:44 AM
In my site after applying a container when I go to Settings->and after changing any settings in the container it's showing error message. Plz help
18 Jul 2008 5:57 AM
I assume that you mean module and not container, as you're showing the module settings page. Is this a custom module? Are you using a custom skin or container?
18 Jul 2008 6:00 AM
Some other things that you can do are:
Look at the event log for a more detailed report and post it here.
Disable AJAX and see if that helps.
Also, which version of DotNetNuke is running?
Forums > DotNetNuke® > DotNetNuke® Questions > Showing error after changing the settings in Container
WOW GOLD by wowgolds987
RE: Pop up window by yerann
RE: Events calendar by mjbieg
