Subject: Open menu links in new window?
ericb1
03 Jul 2008 12:33 PM
I'm using DNN 4.7 and the beyondcss skin from speerio.  I wanted to open some menu links in a new browser window because they're external links to my site.  So from the speerio site, I was helped by adding a text module to a page and adding this javascript to the header:
[script removed]
So now any link that's not an index of my site opens in a new window.  This works great.  However, now I would like to use a different skin, and this little bit of javascript doesn't work on the new skin (Flux).  I'm not the best with javascript, but is there something simple that I can do to change it so that it will work with my new skin?  I'm guessing that the new skin doesn't use or recognize some of this syntax?
Any help is greatly appreciated, thanks!
04 Jul 2008 7:32 AM
If you attach the code in a zip file to your forum post we can have a look, thanks,
ericb1
07 Jul 2008 9:24 AM
Thanks so much!  I didn't see that it removed the [script removed]Thanks again.
Attachment: 177242895371.zip
10 Jul 2008 1:39 PM
hello,
It's hard to tell without viewing the original skin and your current skin, but at a guess it looks as though the ID of the menu in the Speerio skin is 'smenu' - perhaps you need to check the ID of the menu in your own skin with the ID of the menu mentioned in the script.
ericb1
But it doesn't look like it uses the DIV tag. I tried replacing this in my javascript, with all of these tags, but nothing seems to work. Thanks again.
Which I guess
15 Jul 2008 2:44 PM
Thanks again for your help.
In the old skin, I can find this bit of code with 'smenu':
In the new skin, the only menu option I can find is here:
17 Jul 2008 11:05 AM
perhaps you could attach the original skin code in a zip so we can have a look?
ericb1
18 Jul 2008 12:18 PM
Thank you so much for your help, I really appreciate it.  Ididn't realize that the code I tried to paste in before didn't work, I had added some comments to the bottom that didn't appear.
Anyway, the attached 2 zip files show the 'old' and 'new' skins.  The .js works correctly on the old skin, I'm trying to adapt it work on the new skin.  I just attached the .ascx file from the skin folder, not the entire skin.  If you need to see the whole skin, please let me know and I can re-attach.  Thanks again!
Attachment: 171818187471.zip
Attachment: 171818187454.zip
ericb1
18 Jul 2008 12:23 PM
This forum re-names attachment files, so the old skin is called '171818187454.zip' and the new skin is called '171818187471.zip' thanks again!
22 Jul 2008 6:14 AM
ok, looking at the old skin code, a div tag surrounds the house menu with the ID of smenu.
So, the script looks for any links inside the ID of smenu.
Looking at your skin, you are using tables, and this has the code of:
td class="menu-td"
Around the SolpartMenu, so perhaps you could try adding an ID="smenu", or replacing the table with a div with the ID.
Forums > DotNetNuke® > DotNetNuke® Questions > Open menu links in new window?
WOW GOLD by wowgolds987
RE: Pop up window by yerann
RE: Events calendar by mjbieg
