Subject: How to imit the number test periods in Manage Services
wolfgang.nester@bredband.net
13 May 2008 5:29 AM
I’m using the Manage Services page to enable registered users to test a service. For this I’ve created a public role and in Advanced Settings added the following settings the actual service:
a. In the Trial Fee text box, entered a zero fee amount to be charged for a trial period.
b. In the Trial Period (Every) text box, entered a number of 30 days, for the test period to expire.
So far everything works fine. Clicking on the test-link beside the service activates the service and informs about the expiration day for test, just as wanted.
Now to my problem:
Clicking on the test-link a second time (or any number of times) will just count up the period with 30 days each time.
Is there any way to prohibit the renewing of the Trial Period, enabling offering of just only one single period for a trial?
Thx
Wolf
19 May 2008 7:01 AM
This sounds like a bug, I would report it to the core team.
Forums > DotNetNuke® > DotNetNuke® Questions > How to imit the number test periods in Manage Services
RE: GoDaddy by greenflash
RE: GoDaddy by aggiedan97
