Subject: Forum - My Setting ERROR
ajoshi
09 May 2008 8:21 AM
For one of my forums, when I go to My Settings I get the following error.  Any suggestions?
Error: User Settings is currently unavailable.
DotNetNuke.Services.Exceptions.ModuleLoadException: Object reference not set to an instance of an object. ---> System.NullReferenceException: Object reference not set to an instance of an object. at DotNetNuke.Modules.Forum.UserSettings.SelectMultiTreeItems(DnnTree objTree, Int32 ForumID) at DotNetNuke.Modules.Forum.UserSettings.Page_Load(Object sender, EventArgs e) --- End of inner exception stack trace ---
Nuke Master I
Nuke Master I
09 May 2008 9:34 AM
Is the forums module working othewise?
ajoshi
09 May 2008 9:39 AM
Well, what I am trying to do is configure email notification for the forum. So if there any new posts, all users get an email. If I try to do it under host account, I get the error above but I have an another Administrator account, I can do it through that. I am not sure if this is a big issue but I shouldn't have to create additional administrar account. Host account should be able to do it.
Anyways, goign back to the email notfication problem. A user gets an automatic email when he is registered to the forum but the posting email notification doesn't work. Any suggestions?
Thanks in advance.
Nuke Master I
Nuke Master I
09 May 2008 10:16 AM
Are you using the stock DotNetNuke Forum module?
If so, it's possible that there is a bug. I note that I don't get notifications from the forums at the DotNetNuke website. You might want to ask over there if there are problems.
Forums > DotNetNuke® > DotNetNuke® Questions > Forum - My Setting ERROR
RE: GoDaddy by greenflash
RE: GoDaddy by aggiedan97
