lynn
Nuke Master Posts:276
11/17/2006 4:23 AM |
Hi Lee
In your "Skinning Toolkit" tutorial you have css classes for the horizontal SolPartMenu. Are some classes specific to the vertical menu not mentioned in this article? If so where might I see an example of the classes for a vertical SolPartMenu? Or does it use the same classes as the horizontal menu, if so which classes do I need to edit to create a vertical menu?
In your tutorial "DotNetNuke SolPart Menu Uncovered" it is mentioned that the SolPartMenu can be used as either: Horizontal or Vertical Display.
Where might I see an example of a verticle SolPartMenu in action?
Lynn |
Lee Sykes DNN Creative Staff
Nuke Master VI Posts:4945
lynn
11/17/2006 4:39 AM |
Wow!!
Very speedy reply, I sometimes wait for days in the main DNN forum.
Lynn
vidapura Posts:10
01/03/2007 8:46 AM |
Hi Lee,
i have been working through the skin videos from issues 5&6... i got to a bit about making pure css skins and removing the solpart menu. I'm a litte bit confused. i was hoping to make a pure css skin (eventually) that features a vertical menu (something like www.itag.ie) .. so does this mean that I cannot use the solpart menu in a pure css skin? Or is it just that I have to remove the solpart menu from containers in a css skin?
Does that House Menu support the multlevel menu and submenus in the same way as on that site I'd like to emulate ? (ie: www.itag.ie)
Thanks Vida |
vidapura Posts:10
01/04/2007 3:41 AM |
Ahh , great service as ever Lee, thanks very much.
Just one little addendum... I'm working through the tutorials, but I'd like to just see where I'm headed... so just wondering... though I haven't searched extensively for it... is there an example/tutorial that shows how to use images as background in a solpart menu?
Vida |
vidapura Posts:10
01/04/2007 4:01 AM |
Posted By leesykes on 04 Jan 2007 3:52 AM
>Hello,
>This tutorial http://www.dnncreative.com/Howtocre...fault.aspx > use a background image for a vertical SolPartMenu.
Yeah, thats the tutorial I'm currently following (at home in the evenings)
>But it doesn't use a background image for each element in the SolpartMenu.
heh, yeah, thats pretty much why I was asking..
>Does this help? - Or can you give an example of what you are trying to create.
Well, I don't want to put more work on you.... if you had a pointer to a complete skin that had that feature that I could pick apart maybe?
Vida
lynn
01/04/2007 4:36 AM |
Hi Vida, I did have an example skin done for a client, but it's no longer online as they changed their mind and opted for a menu that had a single background image! I would get through the tutorial and then start experimenting with the CSS code, you should find it's not too hard to implement. - I would recommend that you view this tutorial as well: Troubleshooting DotNetNuke SkinsIt will help you when you come across any problems. Hi Lynn, Are you referring to the very last post? - The user has redefined the CSS classes in the skin.ascx file so that the naming makes more sense to them. - Is that what you mean, or I have I missed something? Thanks, Lee |
lynn
01/04/2007 5:14 AM |
Hi Lee The point I was making is that the more recent SolPartMenu (with new skin and tagfix references) might afford Vida, that little bit more, flexibility. Whereas your tutorials and the SolPartMenu uncovered article (below) mention the slightly earlier version. http://www.dnncreative.com/DotNetNu...fault.aspxRegards Lynn |
vidapura Posts:10
01/04/2007 6:22 AM |
Lynn, Lee, Thanks for your help. I haven't gotten as far as the solpart menu uncovered article yet (had a look over it.. still parts I don't understand) but I think I should be ok when I get to it once I take the changes into account. As long as I've seen the www.itag.ie site I know that what i want to do is actually possible so thats most of it really.
Thanks again, Vida |
RS
Nuke Newbie Posts:3
07/11/2008 11:01 AM |
I have Vertical Solpart menu , everything works great except when I try to turn usearrows="true". There is a background image that displays a small arrow on the ft of each Menu item.On turning UseArro- "true" the small arrow to show child pages exists occurs but along with it the background image occors too on the rt of each menu item.( same place as the use arrow arrows appear) any suggestions? |
yassin sayed
Nuke Newbie Posts:4
11/20/2008 12:59 PM |
hi ...
am new in DNN and i have installed Dnn and i work fine but i have 1 think to ask why i can not see the Solpart , House Manu or any other menu except the NAV in the edit mode ,, when i log to my web site as admin or host i can see they Solpart , House Manu on the home page but not ob all the edit pages as NAV Menu
notice the disappeard menu has been add as module not token... (:
please can any one help me |
