Subject: Brilliant! Clear instructions from the very start
seniah08
20 Feb 2008 3:43 PM
I can not tell you how good this site is. I am a beginner to all this with miminal experience in using a wysiwyg page editor. This site goes thru all the basics and as far as I can tell I am going to be using its resources for a long long long time!
Thanx so much Lee (gush,gush)
Sam from The Seniah Group Australia
www.seniah.com.au
Forums > Users Lounge > Testimonials > Brilliant! Clear instructions from the very start
RE: GoDaddy by greenflash
RE: GoDaddy by aggiedan97
