Subject: Unreal site. Worth every penny.
vitalsign0
26 Jan 2008 7:23 AM
Seriously. I shouldn't say this but they are undercharging for the content here. This site turned DNN from an obscure concept to a fully understood powerful application. Anyone can learn DNN using this site.
Because of this site I am going to start offering DNN websites to my clients. As an IT consultant, the value of this site is unmeasurable. Thanks for your hard work!
Forums > Users Lounge > Testimonials > Unreal site. Worth every penny.
RE: GoDaddy by greenflash
RE: GoDaddy by aggiedan97
