Subject: As Kojak use to say - Who loves ya, baby?
MrHappy
22 Jan 2008 8:10 PM
Great tutorials, excellent explanations, suberb resource for the DNN user community!
DON'T you dare go away!!  If you do, we will go to the ends of the earth to hunt you down and strap you to a chair in front of a computer!!
All kidding aside, I'm glad I found your site. I'm positive I would never have progressed as far as I have without your help. You and your team are an extremely valuable resource.
Please keep up the excellent work!!
If you ever get a chance to come to Dallas, TX, please let me know. I'll treat you to some ice cold beer and Texas BBQ. What are you waiting for???
Are ya here yet?
Thanks again!!
25 Jan 2008 7:40 AM
Cheers! - if I get the chance to come over I will definitely take you up on an ice cold beer and Texas BBQ!
Forums > Users Lounge > Testimonials > As Kojak use to say - Who loves ya, baby?
RE: GoDaddy by greenflash
RE: GoDaddy by aggiedan97
