Subject: Wish I'd subscribed from the start..
wolmar
21 Jan 2008 1:39 PM
I started with dnn a few month ago and I must say I did not understand much. Never the less I'm a big fan of www.fu*kinggoogleit.com so I went to work with a vengence! This site pops up quite often with (what seemed to be) the solutions to my first basic questions. Stubborn as I were though I just didn't want to pay. =) I meen.. there must be places where I can get it all for free right?
Wrong! There isn't. And so far this has been my one stop site for all my dnn needs! Had i subscribed from the start instead of searchig googles for hours I would have saved a lot of money. No scam, just great tutorials! Will try the forum now. ;)
Forums > Users Lounge > Testimonials > Wish I'd subscribed from the start..
RE: GoDaddy by greenflash
RE: GoDaddy by aggiedan97
