Subject: Excellent Help for Designers!!!
rjuhl6
01 May 2008 10:05 AM
Excellent work!
Thank you, Thank you, Thank you. You may have single-handedly saved my job. I’m 95% designer and 5% developer. All of the documentation I’ve found for skinning is created by developers for developers. It was very difficult to understand the work flow till I found DNNCreative and your tutorials. Well done, Sir!
Forums > Users Lounge > Testimonials > Excellent Help for Designers!!!
RE: GoDaddy by greenflash
RE: GoDaddy by aggiedan97
