jncraig,
Thank you for your response. To describe what is happening with my hosting service, here is the sequence that I followed.
(1) Downloaded DNN 4.5.5 and followed wizard to install onto my localhost running MS SQL Server 2005 Express. It works fine in everything. The host and admin let me log in and just fine.
(2) I made a backup flie after I attached the App_Data\Database.mdf file. The backup default name is Database.mdf.BAK.
(3) After I changed local web.config I was able to login back to my localhost. That means I now direct the DNN to use the MS SQL Server 2005 Express. See my attachment at the end of this posting for my local web.config file's ConnectionString part.
(4) I created a datbase file for a hoster's remote MS SQL Server 2005. Of course I have created Login user for the server and assigned roles (asp_net.* and db_owner). Again the uid and pwd in the ConnectionString is appended at the end for your reference.
(5) After I uploaded the DNN 455 installation files and the backup file, I request a restoration service for my database backup file. They said "It is complete," which, I guess they mean they restored my backup file to my remote, hoster's SQL Server 2005.
Now, when I login to the hoster (
http://www.woogonchung.net) the home page comes up. BUT, THE PROBLEM is that I can NOT login as host or admin. Again, trust me. I know my passwords for the host and admin account, because I use them all the time.
Below I have appened two web.config files; the first for the localhost version of my computer and the second is for the remote, live host version.
I will appreciate your help on this long-lasting trouble.
(Note: I blocked the password part of my web.config file with xxxxxxxxx .)
--------------- localhost, web.config ------------------
<!-- Connection String for SQL Server 2005 Express -->
<!-- Connection String for SQL Server 2000/2005
name="SiteSqlServer"
connectionString="Server=(local);Database=DotNetNuke;uid=;pwd=;"
providerName="System.Data.SqlClient" />
<!-- Connection String for SQL Server 2005 Express - kept for backwards compatability - legacy modules -->
<!-- Connection String for SQL Server 2000/2005 - kept for backwards compatability - legacy modules
----------- remote, live host; web.config ----------------------
connectionString="Data Source=.\SQLExpress;Integrated Security=True;User Instance=True;AttachDBFilename=|DataDirectory|Database.mdf;"
<!-- Connection String for SQL Server 2000/2005 -->
connectionString="Server=67.36.254.131;Database=woogonchung_dnndb2;uid=dnndbuser2;pwd=xxxxxxxx;"/>
<!-- Connection String for SQL Server 2000/2005 - kept for backwards compatability - legacy modules -->
