Hello
Using windows explorer to navigate to c:\inetpub\wwwroot, then right click and select "New" -> "Folder" and create a folder with the same name as your existing DNN installation. (If you installed to a different location you may simply navigate to that path and substitute it for any further path references)
If I choose for example mydnn as a folder, and I connect to
http://localhost/mydnn, my website is showing, excepted that ALL my images are not shown. I need to edit each module, to find the correct path for the images. And the path is modified from:
/Portals/0/images/myimage.gif to
/mydnn/Portals/0/images/myimage.gif
WHY ? Where is my mistake ???
I tried to re-do the tutorial 5 times, without success....
I have found that in HOST SETTINGS, relative paths is not null compared to my live website. It is set to \mydnn
How could I modify this please ???
I give up.
DV
