Lee Sykes DNN Creative Staff
 Nuke Master VI Posts:4945
thanhdien
 Nuke Newbie Posts:1
06/30/2009 11:09 PM |
please give me tutorials dotnetnuke |
LeeWebDev
 Nuke Newbie Posts:3
07/01/2009 3:43 PM |
Hi Lee, I just watched my first video tutorial (issue #46) and all I can say is WOW...what a great resource! Your style of teaching is perfect for me...not too fast and not too assuming. Great job! I can't wait to watch the previous videos. One question about this tutorial: I have Visual Studio 2008 Standard Edition and would have thought that the pop-up elements would have appeared like they do with VWD Express, but they don't. Is there something that needs to be turned on in VS to see the elements available to me when editing the ASCX files? Thanks again for this hard work you're doing. David |
Shidler College of Business
 Nuke Newbie Posts:7
07/08/2009 2:53 AM |
Just wanted to drop a line to mention how excited I was to see this month's lead topic was on skinning with the ASCX method! I was just thinking it was about time for me to get into it as well. So anyhow I devoured those vids and am hungry for more. Will there perhaps be a continuation on the subject? - Loren in Honolulu |
David Good
 Nuke Newbie Posts:2
07/09/2009 7:53 PM |
When building the skin, you register the skinobject controls once for each time you use the skinobject in your ascx file e.g. in the tutorial you register the dnn menu twice for two instances of the menu. Is it possible to just register the menu once and then use it twice by changing giving the second instance a different id only e.g. dnnMenu1, dnnMenu2. |
 Nuke Newbie Posts:7
07/09/2009 8:19 PM |
Yes, I have seen almost all of those videos actually. I originally signed up to DNN Creative to learn more about skinning in particular, and your videos have been an invaluable resource! I believe these were the first ones to specifically focus on ASXC skinning though, no? I suppose anything that falls under the category of "advanced skinning techniques" would be of interest to me. Just off the top of my head I might like to learn more about: The DNNMenuNavigationProvider I get the feeling I don't know the full capabilities of the default DNNMenuNavigationProvider. I know you like the HouseMenu (I've used it on a couple projects too -- it is nice), but nonetheless would be interested in doing some fancy things with the default menu. Isn't it a bit better than the SolPartMenu was? And maybe it can do some things the HouseMenu can't do? jQuery Maybe something about using jQuery to make photo slideshows or tabbed content within the text/html module? Well anyway I'm what you'd call a 'satisfied' customer. I really do appreciate all your hard work and look forward to each issue. Thanks. |
07/10/2009 11:40 AM |
Posted By Libertytec on 09 Jul 2009 7:53 PM When building the skin, you register the skinobject controls once for each time you use the skinobject in your ascx file e.g. in the tutorial you register the dnn menu twice for two instances of the menu. Is it possible to just register the menu once and then use it twice by changing giving the second instance a different id only e.g. dnnMenu1, dnnMenu2. Hello, I've just checked that out and yes you can as long as you have a different id. Thanks,
CrizTizzy
 Nuker Posts:16
07/13/2009 11:45 AM |
I thank you BIG TIME for the PDF version, I think I would have lost the will to learn about aspx if it wasn't for that option. It wasn't a good surprise to see that I had to download all the videos in one file (over 334 MB Flash format zipped) and encounter 84 MBs of files for Video 1. Downloading the WMF files is smaller but still over 115MB. That seems to be about 3 times the file size of earlier files. If it's at all possible, please go back to one video per tutorial and reduce the file size. |
07/13/2009 12:51 PM |
Its not possible to reduce the file size, but I would suggest you download wmvs because they are much smaller. I placed all of the videos into 1 zip file as other people have requested that they find it frustrating extracting all of the zips. Why don't you like downloading larger files I thought this would save you time?
I guess I could go back to the single download per video, but I would welcome anyone else's thoughts first, thanks,
ORBID
 Nuke Newbie Posts:6
07/27/2009 10:56 AM |
i use the navmenu on top and on the left side. I found how to link the topmenu with the leftmenu as child. But how can i force the menu on the left to show all menu items.
current situation
On top MenuItem1 MenuItem2 MenuItem3 MenuItem4
menusubitem1a - subsub1 (Expand if you the cursor moves over menusubitem1a) - subsub2 menusubitem1b menusubitem1c menusubitem1d
situation i want
On top
- subsub2
menusubitem1b - subsub1
- subsub2 - subsub3
- subsub4
menusubitem1c - subsub1
menusubitem1d
07/31/2009 5:26 AM |
hello try this:
<!--[if gte mso 9]>
Normal
0
unctuationKerning/>
false
false
false
oNotPromoteQF/>
EN-GB
X-NONE
X-NONE
ontGrowAutofit/>
ontVertAlignCellWithSp/>
ontBreakConstrainedForcedTables/>
ontVertAlignInTxbx/>
/* Font Definitions */
@font-face
{font-family:"Cambria Math";
panose-1:2 4 5 3 5 4 6 3 2 4;
mso-font-charset:0;
mso-generic-font-family:roman;
mso-font-pitch:variable;
mso-font-signature:-1610611985 1107304683 0 0 415 0;}
@font-face
{font-family:Verdana;
panose-1:2 11 6 4 3 5 4 4 2 4;
mso-font-charset:0;
mso-generic-font-family:swiss;
mso-font-signature:-1593833729 1073750107 16 0 415 0;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-unhide:no;
mso-style-qformat:yes;
mso-style-parent:"";
margin:0cm;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
mso-bidi-font-size:12.0pt;
font-family:"Verdana","sans-serif";
mso-fareast-font-family:"Times New Roman";
mso-bidi-font-family:"Times New Roman";}
.MsoChpDefault
{mso-style-type:export-only;
mso-default-props:yes;
font-size:10.0pt;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
mso-ascii-font-family:Verdana;
mso-hansi-font-family:Verdana;
mso-ansi-language:EN-US;
mso-fareast-language:EN-US;}
@page Section1
{size:612.0pt 792.0pt;
margin:72.0pt 72.0pt 72.0pt 72.0pt;
mso-header-margin:36.0pt;
mso-footer-margin:36.0pt;
mso-paper-source:0;}
div.Section1
{page:Section1;}
<!--[if gte mso 10]>
ForceDownLevel="True"
ORBID
 Nuke Newbie Posts:6
ORBID
 Nuke Newbie Posts:6
08/03/2009 2:31 AM |
i already tried it. But it doesn't do anything. This is my head menu: <dnn:nav runat="server" id="NAV_Top" providername="DNNMenuNavigationProvider" indicatechildren="false"> ControlOrientation="Horizontal" CSSControl="mainMenu" CSSNodeSelectedRoot="MenuRootItemSelected" ExpandDepth="0" StartTabId="-1" PopulateNodesFromClient="false" ForceDownLevel="false" ForceCrawlerDisplay="false" /> and this is the child menu: <dnn:nav runat="server" id="NAV_Left" providername="DNNMenuNavigationProvider" indicatechildren="false"> ControlOrientation="Vertical" CSSNodeSelectedSub="MenuSubItemSelected" CSSControl="childMenu" Level="Child" ForceCrawlerDisplay="true" PopulateNodesFromClient="true"> if i click on a childmenu my menu disappear (span is not visible i think) see: www.placidus.be |
ORBID
 Nuke Newbie Posts:6
08/03/2009 3:16 AM |
Any idea why the child menu disappear when i click on one item (from the submenu)?
